turbonut85
Rarely used member
- Apr 11, 2008
OK. This is a dumb question, but, What is the correct  hose routing for the HVAC?? I have converted my 85 GN from the electronic climate controls to a spare 87 manual set up I had laying around...Changed the WHOLE heater box!! The two vaccuum lines from the heater box are naturally different lengths than the original set up. (The car was wrecked on the pass side so I have never seen it all together) So, the question is, does the 87 set up use the twinkie shaped vac cannister that was mounted to the top of the heater box? If so do I connect one line to it from the heater box and one to a vac supply? and where does the heater valve connect? What am I missing???  Any help would be appreciated.:redface:
