salvageV6
Daily Driver
- May 25, 2001
By using your own retarded logic you could easily say the hydroboost was obsolete and out of production on the 1986 GN. It wasn't used after 1985 on the Regals.
What did Buick know about hydroboost at that time, too costly, too much service needed, didn't work that great? You tell us.
Air pressure is never blown into the booster that's what the check valve is for.
My two cars with stock cams easily have 15" of vacuum at idle and can run a vacuum setup just fine.
I don't brake when flooring the car usually.
As soon as you let off these cars you get enough vacuum to run the brakes just fine, most of us have a guage and working vacuum brakes on a car to prove that out.
And it's interesting that a used 23-28 year old, taken out of a junkyard car, vaccum system can still work as well or better than a "rebuilt" powermaster or "rebuilt" hydroboost system.
Assuming you actually have read any of the threads around here regarding problems, and are not just doing your routine six month flyby on the board.
Maybe paying the vendor fees and participating with some real tech. help and good customer service might make your hydroboost customers happier.
