scot w.
GNSperformance.com
- Feb 19, 2005
Well I bought a T-Type that sat for a little bit at one time and the pump on the powermaster seemed like it was getting weak. So instead of spending Gobbs of money to replace a crummy designed system from the start I decided to switch the car over to Vacuum brakes. Well I called up my local (Advance Auto Parts) and looked up a 86' Monte-Carlo Vacuum brakes and on there computer it showed a whole brand new complete assyembly. WITH A WARRANTY!!
1) Power brake booster & Master Cylinder (part # 50-1243) for $138.00
2) 4ft of 3/8" vacuum hose = $4.88
3) Big bottle of DOT3 brake fluid = $4.26
4) 3/8" vacuum tee = $1.98
Advance Auto Parts Total= $ 149.12
A Junkyard Brake pedal from a V8 85' Buick regal= $20.00
.... ( this pedal is in nicer shape than the original)........
TOTAL cost of conversion with NEW parts!= $169.12
Time to remove "junkmaster" system & pedal = 1hr tops!
Time to install new pedal = less than 1/2hr.
Time to install new Vacuum set up to the firewall & pedal = 1hr tops
Time to hook up old brake lines = 5min
Time to bleed the brakes REAL GOOD! = 30-45min
Overall this conversion was totally easy and cheap compared to any repairs or replacement to the old powermaster units and you never have to worry about NOT HAVING BRAKES AGIAN!!!
My brakes work BETTER than they did with the old powermaster system and ALOT less hassle.
Scot W.
Scot W.
