Mike this a great write up and alot of valuable information for anyone thinking of doing the vacuum conversion.
Trixdout, I am too going to order the check valve but need to figure out a way to hook it up to the driver side vacuum port using a braided line. Trying to stay away from rubber lines on this. Especially since my brake vacuum line is tied into my PCV line.
Same here. An -6an fitting on the check valve size is fine, but now connecting it to the 3/8 barb on the vacuum block is the key.
