Vacuum incorrect 85 with 87 ECU
Tampa T-Type
The hose routings are incorrect according to the fender sticker the following is what is now in place and I cannot go over 9 lbs of boost with the adj wastgate rod.
One Vacuum line shares:
Turbo outlet, Fuel Pressure Regulator, Boost Gauge and (Elec Sol round with 2 wire connector on passanger side fender).
One Vacume Line shares:
Outter Wastegate Act to main Vacuum, and Electric wastgate Sol valve.
This is not correct and is lacking the T restrictor that should go from the Act to Boost Gauge.
HelpPPPPP
:confused:
I posted on your other threads and havent heard back....
Are you tightening the rod to raise the boost?
BW
