i take windex and spray on/around the coil pak and along the plug wires before using FLAMABLE brake clean from a spraycan. most of the time wetting the plug wires will show any volt/SPARK leak. get the idea? you will be spraying FLAMABLE gas on a running engine looking for an idle speed increase when you spray the FLAMABLE gas on/near the vacumn leak.do not spray on/near the alt. before doing this, i would hands on go thru the vacumn hoses ,looking for cracked or brittle rubber lines,then snug your lower intake manifold bolts.when you get to the rearmost intake bolts, try to look of run a finger across the lower intake. if there is gobs of an oil/grease like substance i'd suspect an intake leak at this spot.btw....i can keep going.....lol
