SignUp Now!I used Felpro cork on mine a few weeks ago and they worked great.
When I did valve cover gaskets on my 84 I used the Fel-Pro Permadryplus. It is a metal shim with silicone on each side to make a nice seal. The only problem I have had with cork in the past is that they are a mess when you want to take them off.
For the 86/87 it is Fel-Pro Part #VS50156T
Picture is below
i think the cork gasket are better than the gasket above
+1 on perma dry plus. Had to trim the corners a bit. Expensive as hell. But they'll still be sealing well even if you have to go in there 20 times. They also feature the "anti-overtightening spacers".
