May 8, 2010 #1 N northerngn Master Monkeywrench Joined Oct 8, 2006 Messages 770 Do i have to use champ v/c or are there other options... Every one around where i live that has champ heads has the same v/c that id get if i went champ looking to do something different here is pic of valvetrain im using -dan Attachments rockers.jpg 63.7 KB · Views: 256
May 8, 2010 #2 BobbyBuick Well-Known Member Joined May 24, 2001 Messages 2,206 is that just mocked up? guide plates?.also i know my MAs need to be ground to fit the scorpions but the champs fit fine
May 8, 2010 #3 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,881 These are from TA Performance, low profile for roller rockers. I have Champion aluminum heads and Scorpion roller rockers. Bryan Attachments TA valve cover passenger side.jpg 61 KB · Views: 243 TA valve cover.jpg 59.7 KB · Views: 257
May 8, 2010 #4 N northerngn Master Monkeywrench Joined Oct 8, 2006 Messages 770 BobbyBuick said: is that just mocked up? guide plates?.also i know my MAs need to be ground to fit the scorpions but the champs fit fine Click to expand... .
May 8, 2010 #5 N northerngn Master Monkeywrench Joined Oct 8, 2006 Messages 770 BobbyBuick said: is that just mocked up? guide plates?.also i know my MAs need to be ground to fit the scorpions but the champs fit fine Click to expand... yes mocked up i was excited to see how it looked all stacked up!!! Phoneguy said: These are from TA Performance, low profile for roller rockers. I have Champion aluminum heads and Scorpion roller rockers. Bryan Click to expand... awesome those were the ones i was eyeballing sent you a pm -dan
May 8, 2010 #6 C Clark6 Well-Known Member Joined Apr 15, 2006 Messages 1,184 same ones I have. TA's and Champs. Attachments EBAY 019.jpg 68.3 KB · Views: 223
May 10, 2010 #8 vacuum 6 Well-Known Member Joined Jan 6, 2006 Messages 2,401 Phoneguy said: These are from TA Performance, low profile for roller rockers. I have Champion aluminum heads and Scorpion roller rockers. Bryan Click to expand... Bryan, No fit issues at all?
May 10, 2010 #9 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,881 vacuum 6 said: Bryan, No fit issues at all? Click to expand... No problems at all even with AC. Bryan
May 12, 2010 #10 vacuum 6 Well-Known Member Joined Jan 6, 2006 Messages 2,401 Phoneguy said: No problems at all even with AC. Bryan Click to expand... Sweet thanks! Easy to remove the PS cover with AC?
May 12, 2010 #11 Phoneguy Cometic HG stress tester Joined Aug 27, 2002 Messages 6,881 vacuum 6 said: Sweet thanks! Easy to remove the PS cover with AC? Click to expand... Yes!! You can get it out in ten seconds after removing bolts. Bryan
