SignUp Now!The drivers side is leaking from the rear. I tighten them at install and lasts about 2 weeks and start leaking again. I retighten, probably over the recommended specks. But flurstration sets in. I set the covers on the bench they are not warped.Are you over tightening the fasteners?
Are the fasteners loosening over time?
Is it leaking at the rear? If not where?
Is the cover warped? Set it on a flat surface? Head and vc clean when installing new gasket?
I like cork and use some contact cement at the corners of the cover to retain and a coat of oil around the head to seal but not stick so I can reuse if I don't rip it on removal.
I have been fighting the passenger side. I installed a new felpro cork gasket and it still leaked. I removed the valve cover and noticed I did not tighten the bottom rear bolt tight enough. No squish on the gasket. I then dry fitted the valve cover to the engine and noticed my copper header gaskets where real close the valve cover. I clearance the valve cover and they fit a lot better.
I check the bolts every other time I drive it. I didn't want to over tighten the bolts but once they heat cycle a few times because of the cork they will loosen up. I thought I had everything tight the first time but I didn't. If your using cork keep snugging them. You might try loosening the other three and start tightening the lower rear bolt first. If that doesn't work just pull the valve cover and look at the cork for a god seal. Chances are at that point you don't have a good contact to the head or it tore during install.
X2 on the locktite if fasteners aren't staying tight. Blakeclean is good in the holes to clean em out. Careful though it comes back at ya and you don't want it in your eyes.A dab of LockTite blue helps
After cleaning out the holes with some degreaser
Is that really a good idea?? Especially as the gasket shrinks and hardens after a few heat cycles.
I just snug them up every once in awhile to prevent leakage.
It's not that the fasteners loosen up, but the gasket shrinking that causes the gaps and leakage.
Though I do like the black trans pan gaskets I have gotten the last two times. Not near as sensitive to over tightening.
How much heat and shrinkage do you experience with your installations with cork?
