My friend is running a 274 cubic inch stage 2 with a solid roller cam about 230 duration and 590" lift. The setup is Innovative 74 turbo, Mease intake, M&A heads, turbo 400 trans. (with trans brake) shifting at 6500 rpm's,and Ford 9" with 3.90 gears. He is using conical springs with a seat pressure of 150 lbs. The car is not running up to its potential (10.30 @ 134 mph at about 26# of boost) and he is now taking a look at the valve springs. The advice that he is getting is that he would need a least 200 lbs. of seat pressure on a solid roller the keep the springs closed at the higher rpm's. Anyone have experience with type of setup?
Thanks,
Jeff
Thanks,
Jeff
