valve train ?
turbo todd
Yeah its a BUICK!!
Does anyone have a valve cover off, were they can tell me the center to center mesurment (bolt holes) on the rocker arm shaft? I know there is three but would like to know the distance from center to center. ie. the bolt hole for the # 2 cylinder is x from the bolt hole for cylinder # 4. then from # 4 to # 6.
Thank you in advance. Todd.
Going from left to right You have 4.25", then 4.375"
That is, on the driver's side, it is 4.25" between the first and second bolts and 4.375 between the second and third bolts.
HTH
