1986 Buick Grand National Intercooled Turbo V6. T-Top, P/W, P/L, Cruise, Tilt, A/C, P/Trunk, Rear window defrost, Concert ll stereo option. Garage stored with cover.
Exterior: Professional paint job in 2001. All emblems, door locks and handles, wheel mouldings, mirriors, window trim, spoilers, bumpers, lights, weatherstrips were removed, cleaned, painted then put back on. There was not ANY patch panels or body work done to this car in ANY WAY. It was and is a no rust car and all the factory seams for all the panels are visibile and are just the way they were in 1986. All paints were Dupont B/C of the highest quality. New emblems, marker lights, park lights, new Wagner Halogen headlights were installed. New Soft Seal COMPLETE weatherstrip kit, T-Top, trunk, hood to cowl, door sill, inner and outer belt line, window, and door seals were installed. There are no runs, sags, or "orange peel" in the paint. Many hours of prep time were spent to give it the look, shine, and straight body that it has.
This car is in excellent condition, and has no door dings or other small blemishes. It won First Place in a car show on Father's Day this summer!
Interior: New headliner, front bucket covers, headrest covers, upper door panels, sun visors, cruise / turn signal / wiper stalk. New passenger power window motor (I bought both sides; the driver's side motor goes to the new owner.) No cracks, tears or rips in the seats or panels. Real Auto Meter Pro Comp gauges for water temp, oil pressure, volts and boost.
Brakes and Suspension: New BF Goodrich T/A Radials, rebuilt calipers, new rotors, new drums, wheel cylinders and spring kits, new shocks. All shocks and brake parts NAPA Gold. New upper control arm bushings, new upper ball joints, sway bar bushings and mounts. All parts were Moog. Front end alignment and anything that was worn or broken, was replaced.
Exhaust: 3" SS down pipe w/SS heat shield, 2" SS crossover pipe, Hooker 2 1/2" SS mandrel bent exhaust w/cat-cut out.
Transmission: 2800 quik-spool converter, trans rebuilt with super duty clutches. All parts from Aggressive Automotive.
Engine: Power Plate, TE-44 Turbo, 25 psi w/adjustable waste gate, 42.5lb " blue line " injectors with adjustable regulator, 93 octane power chip. It is set to run at 16 PSI boost with 93 gasoline, and there is NO detonation at that level. This car is perfectly streetable with this tune. This is a proven set up from Aggressive Automotive that gives a dependable car for the daily and weekend driver with no problems. Kenne Bell cold air intake with 3" chrome induction tube, and 2 1/2 " polished SS down tube, hot wired fuel pump, Garrett inter-cooler. New water pump, battery, Belden plug wires, radiator and cooling system flush and fill.
This car gets around 16 MPG in the city and 22 MPG on the highway.
Known problems are as follows: Power antenna does not work, never has. There is a 2" crack on the top seam of the dash pad, was there when I bought it. The rear bumper filler is cracked in 1 place, at the rear by the tail light. The front fillers were just replaced and were professionally painted and are perfect. There is a small red stain on the driver's seat.
I have all the paperwork that was given to me by the previous owner showing all the work that has been done to this car over the past 20 years, receipts, manuals, stock parts, and history of owners. Engine and trunk compartments are clean and detailed, the wheels are perfect with no rust, pits or " curbing. "
The A/C is perfect-- all fan speeds work properly and it blows ice cold. It is still R-12.
This car gets compliments every single day I drive it, including today. It will spank anything (well, almost anything) on the road, and is very quiet and reserved in it's manners.
This is a true and exceptional example of the Buick motto: fast with class.
I am the owner, and I am not a dealer. Check my feedback and bid with confidence. I can help with shipping that you arrange. I am a Buick person, and I just bought a 1970 Wildcat Convertible, and I only have room for one hobby car. A pic of the Wildcat is included (below!)
The price is $12000.00.
Many pictures are here:http://s2.photobucket.com/albums/y30/austingta/1986 Buick Grand National/
