BoostMasterK
2 boys now, need more GNs
- May 28, 2001
Is it common for a Vigilante 5-plate to give false knock? I'm not 100% sure it's the converter, but it's my most likely suspect, since it started exactly when the converter was added.
Doesn't "knock" when throttle is gradually applied, but when you hit it quickly, it goes nuts and doesn't stop until you let off. O2's are fine (upper 700s/low 800's).
Any way to be more confident that it's the converter?
Any tips to solve it?
TIA!
Mike [
TIA!
Mike [
