My volt light started to flicker. ONLY when I hit some bumps in the road. It DOES light up when I turn the ignition on at first. The lights (headlights and dash) dim when the light comes on. It only flickers on (less than 1 second). The SM cycles between 13.2-14.1 volts, so I guess it is happening so quickly that the SM doesn't read it.
Going to take the dash apart and clean connections and buy a new bulb and see what happens. I tried to wiggle some wires off of the alternator and it did not flicker at all
