Walk me through ow to measure my pushrods
jdpolzin
OK guys, I have no idea how to measure for the correct pushrod length for my 4.1. I have a 291 4.1 block that has not been decked and stock 8445 heads that were not resurfaced. I'm going to be running a Comp 216/218 cam. Gross Valve lift is .485 intake and .489 exhaust if that matters. I'm usinng the Federal Mogel lifters. This is a flat tappet cam. I'm using the stock rocker assy also. Will you walk me through what i need to do and what tools I need. I have no tools to do this job so I'll have to go buy some. The lifters are soaking in oil now. Unfortunately while installing the cam, I noticed the machine shop gouge the rear cam bearing so it needs to go back to get that fixed......I have time to read and buy tools now! I was planning to use the stock pushrods if I can and have been told both ways. Some people say thos pushrods will work, others say they need to be checked anyways. I decided I better check them and it will be good practice for the next motor anyhow!;) BTW....I'm using Felpro 1000 head gaskets. Thanks for the help guys. ----Jeremy
Ok guys! Thank you for your great info! I will be doing some reading thats for sure.
How many of you guys vote that my stock pushrods will be the right length?
Stock pushrods - depends
If the deck height of the 4.1 was unmollested prior to your ownership and is the same height as the 3.8 a stock push rod should work. Otherwise it won't.
The tools required to do the check are inexpensive and the procedure is pretty cut and dry. So don't do what I think you trying to do gain confidence the stock pushrod will work. If your geometry is off you risk breaking something or at a minimum wearing something like the guides out.
The 4.1 and 3.8 deckheights are different. I have stock 4.1 pushrods though. Deck height wasnt changed, heads were not resurfaced. I'll see what I come up with it.
After reading those two articles, I'm still confused!:confused: Please bare with me here! These articles most deal with adjustable rockers and roller rockers. Is there any info that can be a little ore specific to our stock parts? I have read and read and searched every thread I could but really have not found any step by step info. I think this should be a pretty popular question for our cars.
