WANTED: RJC Billet Crank Pulley
GNBRETT
Pelennor Fields
RJC Billet crank pulley for electric water pump. New or used is fine. Black is not. Thanx
No one has an RJC billet under-drive pulley for an electric warer pump? Cmon guys someone has to have one. Im not looken to rob anyone. I just need it to help finish up this blood sucking project....
what other accessories and what kind of accy bracket are you using?
if alt. only, use a stock pulley
if alt and p.s. use a underdrive pulley.
A pulley like this Billet Race Crank Underdrive Pulley.
Underdrive pulley was designed for guys that would like to run electric water pumps on their Turbo Buicks. The size of this pulley is crucial for the proper operation of the serpentine belt system when running an electric water pump. If the pulley was any bigger or smaller there would be belt rubbing problems. This pulley takes all of the guess work out for you and makes electric water pump installation easy.
Vendors are out.
that pulley is only necessary if you are using the stock accy setup.
if you switch to a champion accy bracket, you dont need it.
