I will try to make this short.
Oil pressure 20 idle, 60 WOT on all engines before problem starts.
First rebuild lasted 4000 miles, main bearings went out, rebuilder
did not know why.
Second rebuild lasted 500 miles, disassembled myself and found nothing, took block and main caps ext. to a diferent rebuilder to have it checked out, everything was fine.
I decided to go with a completly different engine, bought a low mileage long block that was in excellent condition ( inspected by a rebuilder and myself) It lasted 300 MILES!. mains again!
It is ok until I make a WOT blast into 3rd gear then oil pressure starts dropping , then the knock ( mains) follow shortly after.
Inspected new timing cover (GM) that has been on all the engines and found the outlet side (inside the pump gear housing, the tapered hole along side the pump gears- towards the front of the engine) is smaller in diameter than other good timing covers- about 30 thousands.
Need opinoins.
Going nuts.
DW
did not know why.
Need opinoins.
Going nuts.
DW
