Wastegate question, please dont kill me
oldsracer
Identity Crisis
This may sound dumb but trying to learn everything. If I take the stock turbo and take the wastegate parts off will it make it into an external wastgate turbo or is that not right. I understand external wastegate doesnt have to do with the turbo as much as an internal wastegate. Any input will help and if you must make fun of me feel free:)
Just run the internal gate setup. Plenty of fast cars out there with it so it works. I'd get a manual boost controller though when you are ready to turn up the boost.
the only way to remove the wastegate on a stock tr is by removing the elbow housing on the exhaust side of the turbo. it will reveal the exhaust wheel on the turbo. If aftermarket, the waste-gate puck is an integral part of the downpipe. the part that bolts to the turbo housing w/4 bolts. If you go on trcustoms web site, you can check out Marks pics on the d/p's. they are gn-1's, but Mark has the 3 differant types available in the pics. you will see the difference. the external is like a relief valve w/a diaphram and you control it's operation by adjusting the pressure. Hope this helps.
