Dr.drivability
9 second wannabee
- Oct 1, 2005
Anybody know anything about Breitling watches? I Came by it years ago and was always curious if it was real.
SignUp Now!Should have known Gary "Rockefellar" Wells would have known about them:biggrin:
Rockafeller lolz !
Actually, Ty, I am very fond of Omega watches, and that is all that I will wear. And that's older Omega watches, as the newer ones, just like anything else, doesn't seem to have the same quality & integrity that the older ones did. All of mine are of about '85 vintage or so. And that's only 3.Should have known Gary "Rockefellar" Wells would have known about them:biggrin:
Ty:hahahha we all know he holds the keys to FT Knox:biggrin:
I took it to a local jewler and they couldn't tell if it was real. Probably didn't want to hurt my feelers!! I don't care, I like it whatever the case!! Supposedly this model was produced for the iraq gov't. Pprobably BS!!Doc, I would Check the web, ebay, local pawn shops & jewlers. The last 2 mentioned can prolly tell you the most as they know what to look for physically.
If it works it is a PLUS
DO NOT TRADE IN TO a PAWN DEALER.. These folks are horrible as you will get offered 10 cents on the dollar maybe less.
I know quite a lot about breitling watches. I'm a watch collector, and it's been my hobby for a little bit. Though, the serial number check is a nice way to tell, some VERY high quality copies have been coming thru my hands lately, and they are truly top notch, fake 'genuine' serial numbers and all. There's only 2 ways, you can truly tell if it's real.
1. Find a watch repairman, that has been in the business of HIGH END WATCHES, for more than 20 years. (no, your local watch repair man, most likely, has only touched a few genuine high end watches in his life. THOSE people are quartz battery, cheap watchband, and rubber gasket switchers. They replace those parts all day, and charge you 40 bucks and go. Those are not watch repair experts. You'll have to find one that's been operating in a very rich neighbourhood for quite some time. They'll say that have experience on high end watches, but they lie. trust me. I've asked QUITE a few basic questions, to these people, and they couldn't answer me.)
Then have him remove the movement, and look around. From his memory and hands on experience with many brietlings, he'll be able to spot any discrepancies.
2. Send it into brietling, and have them do it. Though they will charge you a bit to do it.
If you find out it's real, I'd get a service on its movment, and wear it. Though, again, try to find a local repair man, because if you have brietling do it, it will cost you several hundred dollars.
All that is true... unless it's a REAL good copy... which like I said, noone will be able to tell, unless they're VERY experienced.
China has a factory there, (I don't know the name any longer) that is punching out extremely good copies of high end watches, and are correct in every way. Serial numbers, genuine sapphire crystals, SOLID band links, solid end links, screwed not pinned band links, genuine stainless construction, no 'made in xxx' stamps, laser or hand punched markings, not acid etched, screw down crowns, quality spring bars, screw down casebacks, proper lume, and the correct bpm automatic movements. The only way you could tell, was the actual finish of the gears inside the movment. They weren't finished to the degree the genuine articles were. This is stuff you'd have to feel with your hands, or see under a loupe.
Again, this stuff would have only been found, by a person who was used to looking at the originals for quite some time.... Though, these copies were still kind of expensive and they end up, just by accident, to be not soo bad watches lol. Still fake nonetheless.
I've seen two in my hands. A Rolex and an Omega personally. They were amazing.
Which now because of these copies, I will never own a Rolex. Or a real diamond either.
(I have a good buddy that was a famous jeweler for a long time, and he says that there were counterfeit diamonds out there, that noone could tell, not even him.)
Now, if I see someone with a 400,000 dollar watch on, or a 55,000 dollar diamond ring on, I simply won't believe it. So now, all that expensive jewelry is absolutely worthless lol.
