Weatherstrip retainers and trim ?
TURBOV8R
Gota dubl u e 4
In the process of removing T roof weatherstrip and while cleaning out the screwed on retainer strips/trim that run up the A post and the rear between the roof and top of door,need to know if the shade of black is the same as the wheel mouldings,handles etc.Mine were sprayed the same gloss as the body and I've seen other cars that were repainted and some had trim that were painted gloss,semi gloss,and flat.I would assume that they(blackout trim) were all the same shade?Not trying to be concours perfect but this is the type of trim that is not so easy to remove if painted incorrectly
If I am not mistaken, all of the trim should be a satin black (not flat, not gloss but somewhere in between).
HTH
