ok Getting ready to send my classic fast b2b back to have it checked over.
Here is whats going on. 89 camaro sbc factory HEI. I put new heads on the car and start it up and notice a miss. #2 #4 pistons are not firing at all. Plugs look brand new. I check spark yup got spark. I pull both conectors for those two injectors and have 12 volts and used a light bulb to test. Both connectors flickering well just like the others. Last maybe those two injectors are dead? I pull both injectors and move them to 6 and 8 and move 6 and 8 injectors up to 2 and 4. Start car up and let it run for a minute and guess what pull the plugs and 2 and 4 still not firing. I pull the valve cover and valves are working fine. So this seems impossible, why when i make a change the car breaks some random other part. The worked great before the head swap.
FAST is going to check the injector drivers to see if they are week but they admitelly find it very odd.
