- May 28, 2001
Neal Steward ran a 10.2 on the 4th pass with new motor in november...![]()
Correct me if I am wrong...
oops someone beat me to it
If there is anyone here that thinks you just drop a motor in a Buick and start running 9s all day, boy are you in for a rude awakening.
Jeff did not get to 9.40 timeslips the second he bought a TA block and heads. It took 2 years after that ( guessing Jeff ) before he hit that goal.
Neal did not run 10.40s with a stage block or 10.20s with a 109 block overnight either. Anyone who knows him knows he takes his time with each pass, analyzes the data, tries it again and again.
Scott has worked up to his times and speeds as well. That is with 2 different blocks. One is in many pieces inside and the other is working well so far.
It does not matter which block you are trying to use. It does take more money than you thought. It certainly takes more time than you will like. And you will be breaking parts you did not think would break.
Anybody who says otherwise is trying to sell you something.:biggrin:
