Originally posted by ijames
Hmm. Sounds reasonable as to hp and air. Any chance you had a wbo2 sensor to get the actual air-fuel ratio? Assuming this was with race gas and higher timing (25+ degrees) you could probably use 0.5 as the bsfc and calculate the actual airflow just to compare. Otherwise I'm out of ideas just now, sorry.
Wide band was present.
Car #1 13.7
Car #2 12.7
Timing was at 16 degrees (factory is 12)
110 Octane
I should mention this is a 135 CI 4 Cylinder?
But that should not really change anything, afterall it is just an engine, right?!
