I got my car on a dyno last weekend. I have an SMC progressive kit and a TT alky chip on a fresh engine. First pull was 423hp very rich, I raised the alky start point to 12psi and Max to 22psi. 2nd pull 432hp still very rich. I left start at 12psi and raised max to 26psi. 3rd pull was 439 hp but still very rich. This is where my cam sensor failed and ended my day. My next step was going to be lowering wot fuel 10% by the TT chip. Is this the best move or should cut the alcohol. I'm running straight denature alky (homedepot stuff). Car was so rich the wideband on the dyno jet could not read it. O2 readings start at 10 and my car was still below. Boost is steady at 25 psi. I ordered a cam repair kit and will make another dyno appointment as soon as its in.
