Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
If you got to the Bud show I can show you the Powerlogger and how it works.
SignUp Now!If you got to the Bud show I can show you the Powerlogger and how it works.
BTW, dyno's cause vehicles to go rich about .5 in the AF/R so don't be alarmed if your street AF/R reading and dyno reading are not the same.
I've heard that before. What causes that?
I believe it has to do with the MAF and how power enrichment is handled. This is Buick only curse. This is why these cars dont Dyno well.. My own cars I have tweaked them at the track playing with timing and airfuel.. then putting them on a dyno and run like crap.
if i understand the original post this is a not a stock motor so i don't understand the discussion about the stock headgaskets.any tuner that understands the 2 different fuels will not recommend a 11.5 afr regardless of which motor or headgaskets.i would not start tuning at 25psi, there just is no margin for error,drop the boost, pull some timing, and work your way up.
