Just got finished buttoning down everything on my car. I changed the valve springs with Comp 980's, finally added the RJC ADPP, and changed my FPR from a 237 to an AccuFab adjustable.
Anyway, after I got everything back together, I was super excited to start the car, even though I haven't set the fuel pressure. Anyway, I cranked the car, and it fired like it always has, but only there was a pretty loud popping sound every once in a while. It almost sounded like something whacking the valve covers or something. I did NOT let it run long (maybe 5 seconds), but by the time I turned the key off, it seemed like it might have smoothed out. So I tried to crank it again and no-start. I didn't crank very much on it because I'm worried about what MIGHT have happened to it. Also, there was a slight amount of smoke under the hood for the few seconds that I had it running.
The only things different on the car are the vavle springs, the RJC PP, and the Accufab regulator, and running maybe 2 quarts low on anti-freeze (I removed the coolant lines along the PS VC in order to get better access to remove it). Oh yeah, I did NOT reconnect the factory boost solenoid as it's no longer in use. Could this have a bearing? Do I need a new chip due to the addition of the FPR or PP?
Any ideas on what I might have screwed up? The only thing I can think of is maybe, possibly, the rockers (I looked up torque and set them at 25 ft-lbs), or maybe one of the push-rods wasn't seated correctly. I checked each pushrod before, during, and after the rocker installation to be certain they were in there correctly...I'm sure of it. Can you guys help me come up with some ideas on what it might be?
Should I go ahead and tear it apart again for inspection, or get the FP gauge out, try to set the FP, then worry about it??? I'm starting to get pretty sickabout this, especially since I was very confident that I did everything right during this whole ordeal.
It did take me an extra long time to get this done what with travelling for work. Passenger side is an absolute B!TCH!!
