incubus2432
Douchebag
- Jun 23, 2006
The weather has finally gotten consistently decent so I was able to wrap up some jobs started over Winter. Basically, I got my 9 gauge GNX dash in along with swapping the dual console gauges out. In the dash is now speedo/tach/fuel/fuel pressure/trans temp/coolant temp/oil pressure/boost/volts and the console has pyrometer/wide-band. All gauges are Autometer 'Phantom" series. Running all of the sender wiring was a PITA to get done neatly but it came out great and all of the gauges work well EXCEPT for boost.....it's probably just a kinked/pinched hose so it should be a quick fix when I get a minute or two.
When I finally fired the car up there was a little light smoke from the engine compartment that cleared up after a few minutes.....just oil residue from various mini-projects over winter.
I also drained the winter antifreeze and refilled with distilled water, Red Line water wetter and a valvoline additive to lube the water pump and inhibit corrosion (I forget the name). Also topped off the alky reservoir.
The car ran great and felt strong. The only problem, besides not being able to hammer it too bad due to the boost gauge not working, was that the turbo oil feed line was leaking pretty bad but once snugged sealed up fine.
It's good to have it up and running and I look forward to upcoming projects throughout the Spring/Summer.....installing the Hydroboost (if the rest of my parts ever get here), Baer brakes front/back, fixing rear main seal and installing shift kit. Good times, good times.....
