SignUp Now!What fuel pump,turbo,and injectors do you have?i have a 87 gn and thinking about running e85 what do i need to change to run it ? thanks
I think those injectors would get the job done. Put them in and get an Extender chip. Done.everything is stock but a 340 fuel pump , have some 009 injectors to put in
Don't you need at least 50lb injectors? Why not just step up to 60sI think those injectors would get the job done. Put them in and get an Extender chip. Done.
He already has 42s. They're enough.Don't you need at least 50lb injectors? Why not just step up to 60s
I read,from your writing,that you would like to use what you have if you can. You can and I would if I were you. The points that Boost231 makes are valid and true. If you are more concerned about cost now and whether or not you can do what you want with what you now have,I give you the green light. You'll be near the limit of these injectors,only,if you run up to 21lbs of boost. Your O2s and spark retard will tell you where you are and how high you can go. If,after making a richer fuel adjustment in the chip,you don't see a corresponding increase in richness from the O2 sensor,you can raise the base fuel pressure. You're going to want to see an O2 number of 835 when you first go WOT. Then it will fall the longer you stay in it.so put the 42s in and get a new chip , sounds good ....
