what do you think of my combo
87lightweight
let me know what you think of my combo and what would you change
.030 over 109
ported polished heads larger valves heavier springs
206/206 cam
stock intake
stock throttle body and plenum with rjc plate
60 pound injectors
adjustable reg.
lt 70 p trim turbo
rjc front mount
walbro 340
th 3 inch downpipe
hooker cat back exhaust with cutout
stock maf
tin man air intake
3inch maf pipe
have not done tranny or convertor yet
Without a converter it will be a pig. A good one is required. Get a billet shafted forward drum fr the trans minimum. You will need to keep the rpm down under 5600. Id get a matching intake manifold and do some suspension work. A set of M/T DR's on lightweight rims will help a lot. The converter is the biggest problem though. Check out PTC.
That ought to be a good choice.
But like the man said get at least a few billet internals.
With your combo you will need it.
It will save you in the long run or short.....:biggrin:
I have one of Brians works great.
