Drewster
Wish I Had A Clone. AKA Andrew Youlio
- May 31, 2001
I tried to use the back end of 12" dial calipers to measure lifter preload. i got measurements around .100in. (difference between loaded and unloaded lifter plunger). i wanted to find the most accurate method as the calipers were not on centerline when measuring
I saw the GNTtype article about using a wire style gap tool but that didnt make sense trying to measure depth.
what is an accurate method? maybe dial indicator on top of the rocker arm and pushrod?
Andrew
motor almost done.
Andrew
motor almost done.
