What does the line bias valve do?
  • Thread starter Thread starter bry593
  • Start date Start date
B
bry593
Guest
I'm curious as I have just added the Superior inner spring to my factory CZ spring and want to make sure I didn't just cause myself some grief.
Many thanks,
Bry593
I appreciate your reassurance...
But, that doesn't teach me a thing. I'm a quick study. Give me a hint.
Truly appreciative,
Bry593
It's kind of a strange animal.
It is designed as a mini-regulator for the TV pressure that is sent to the main TV boost valve in the pump.
At a certain throttle position, the line bias valve will slightly reduce the TV signal to the main regulator; ex. TV press. = 75 psi, line bias press.= 71 psi.
A stiffer spring will raise the point at which this pressure reduction mode takes place. At TCI, we like to simply block this valve closed; i.e. no reduction.
That is correct.
I went to post what it did in the correct terms and when I came back to repost. Greg had answered you. It also will keep it more stable, but a regulator to tv is a good way to put it.
Bruce
WE4
www.PTSnctb.com
Thanks guys!
I was having a difficult time getting that out of the ASTG manual.
Bry593
You won`t either Bry ,but if you get yourself a Principles of Operation THM 200-4r it kind of explains it & other things too.
You have to call Helm`s to get it you can`t order it online.
1-800-782-4356
I`m kinda waiting for Bruce`s book to come out :D but I`ll prolly be long gone by then.
Jim
Sometimes the principles of operation book is available on eBay. I got mine there for $15. :D But that is hit or miss though. :(
Chvl66
Is this the same as the General Motors publication?
I have found several copies of the GM publication of 2004R Principles of Operation. They are copyrighted early '80's.
Is this the same book?
Bry
