this motor has 1500 miles on it. it started to have a knock last week so i pulled the motor. basically all of the mains are TRASHED. What would cause this? even the thrust bearing is wearing. the bearing in #3 seems like it doesn't even fit right in the cap. when the motor was rebuilt i put in a NOS standard crank and had the rods resized.
all the rod bearings have a little wear but #1 was pretty beat up compared to the rest.
until last week the car always had 75 psi cold oil pressure, 25 hot idle and 50+ while cruising. it has a high volume pump and the main bearing holes were drilled. i've changed the oil at least 3 times.
i had the car at the track last week for the this time and thought that it was getting a little knock (detonation) but now i think it was the bottom end knocking. i was only running 16-17 psi of boost with 60lb injectors, hot wire, and a walbro. i've never had detonation issues. my 02's were always around 800 at WOT and i have a caspers knock gauge. i haven't checked the fuel pressure climb lately but i did when i first put a bigger turbo on about 1000 miles ago and it was fine. and if the fuel pump would crapping i would have picked up knock before.
what happened?
what happened?
