What happens to driveability when...
S10xGN
RETIRED!
... you have the boost sensing cable in place of the MAT sensor? My truck stumbles bad and idles like cr@p when it goes closed loop. After it's hot, if you shut it off, then restart after > 10 minutes, you have to sit and feather the throttle until it goes into clsoed loop for it to stay running (stalls).
An experiment: does it run any better when you take the boost sensing cable off and put everything back to normal? :) Not to be a smart ass or anything :)
I never noticed my GN running any different when I had the boost sensing cable on it. As far as what happens, your ecm will be seeing the MAT jumping around as manifold pressure changes. Depends on your chip I think whether or not the ecm makes any adjustment based on that.
John
It shouldnt make any difference.
Are you sure you have a 3 bar sensor?.
John: it seems like I've tried that, but my memory is unclear, so maybe I'll do it again to be sure (getting old sucks!). :rolleyes:
Bruce: I'm pretty sure I've got a 3 bar, but what difference would it make to the idle quality? And how could I tell for sure that it is a 3 bar sensor? ;)
