What injectors are these?
Thank you sirs.
I have a 36# injector chip... that came with the car, would that work well with the 40.1lb injectors?
Thank you sirs.
NO
it will be rich beyond capability of ecm to correct without lowering fuel pressure (a lot),
at wot it would allow for a little more boost than chip was burned for
Thanks Paul. So I would assume its not safe to move the car with th chip? Has to go about 3 miles to get to my house.
-Chris
for t that short i wouldnt worry , it will start and run but will be rich at first (about 12%), the ecm can adjust about 6% but will take some time to learn , more than youll use driving it ,
if you can back the FP down to maybe 35psi (static) and it may be just fine
