Thanks GNVYUS 1 the fueling issues are good. The data log showed an injector DC in the 70's and the afr was hovering around 11.1 I only have a 4 point cage in it now. I raced at a grudge match They let me run but I was informed I need to add the additional points to the cage as well as a crossbar so the weight should go up allittle.
Bison I was shifting the car at 5800 to 5900. It seemed to be pulling all the way to there. Are you saying I should be shifting it at 5200 to 5300. Also what symptoms should I be noticing with the valve springs the way they are because I did not notice any, it pulled really smooth. If you were to change the valve springs which ones would you use. What benefit would there be to go to the roller rockers with the larger 1.66 ratio for alittle more lift to that cam? I have a really nice port job on the heads and better valves, could that be why it ran to that rpm?
Of coarse I want the 9.40's:biggrin: But what do you see as the downside to going with the 3.08's as opposed to the 3.23's Is there a down side to going with the 308.s If I was to guess I think you are going to say at lower boost levels the 3.08 are going to not work very well. Thanks guys I really appreciate the answers and I would love to see this thing crack off a 9 sec pass
