- Feb 14, 2002
YO!
I can state with a very high degree of certainty that the DW pump does NOT overwhelm the stock fuel lines. Fuel pressure at idle is right at 38psi line on on my car.
I have a pile of fuel pressure data using the DW pump on a stock motor / TA49 / E85 car.
In a Buick with stock fuel lines and GOOD WIRING all the way to the pump, including the fuel header wiring being GOOD, the DW pump can readily support 60-65Lb injectors with full 70-72psi fuel pressure in the rail and high boost (25-27psi boost). I strongly suggest using a racetronix fuel pump hanger wiring upgrade. Makes no sense to run a hotwire without upgrading the hanger wiring too.
Here's some data with 80lb/hr injectors
