TURBOPOWERED68
David
- Jan 31, 2006
What is the proper way to do a Compression check?
I have done it like this in the past
1-run the car until it reaches normal operating temp.
2-disable the ignition
3-remove a spark plug
4-connect compression gauge
5-hold the Throttle at wide open position
6-then crank the engine a few times
Is this correct or should I or do I need to change something?
