Not the problem. The map sensor does nothing but light up the boost gauge on an analog car. To figure out you issue, you need to see what the base fuel pressure is, what fuel pressure is when on boost, reading from the mass airflow sensor, AFR, boost pressure, octane, knock retart. Most likely will be an easy fix, but figuring out the problem is tough without the proper tools and know how.
