what is turbotweaks lockup settings?
liv4gnz
does he put a preset lockup setting in all his chips?
how do i know what he put in mine
im getting a new converter and i do not want it to lockup up under WOT
just part throttle and cruising
how do i know what i have and do i have to reset the chip for a bigger stall converter
ok any one know his email again so i can tell him im gonna send mine to be re burnt
I get this question a lot for some reason.
I never set chips to lock the converter at WOT, UNLESS the customer specifically tells me to lock it at WOT. It doesn't matter if it's a street chip, alcohol chip, or race chip. I never set it to lock at WOT by default.
For cruising, I set it to 45-50mph, unless the customer specs something else.
Eric
no , if you want lockup hookup a switch to pin f on the aldl and ground
Eric
ok so i didnt tell you any preferance on lockup so its only at cruising than and it will NOT lock at WOT??
i wanted to make sure before i break something when its going down the track and locks the converter and that is going to be :biggrin: to :confused: :mad:
