what should it make.
rddrivers321
Here is the combo I just built, I would like to know what kind of HP and Torque it should make. Here is what I had build:109 block 30 over, TRW piston, stock rod, stander crack, RJC Gridle, GN1 port heads, 1.65 T&D rocker, champ port match intake, 70mm hemco dog house and throttle body, Red's pumps, 215/220 roller cam, FMIC, LS1 maf and Hp in a box, 65 lbs inj, race bottom pulley, ATR heard, down pipe and waste gate, t70bb, 3" torque cat back system, metco upper and lower control arms, 9x11, built 200r4.
What should I add or change to my combo to get a 10.50 or better time slip. Thank for all of your help.
I would strongly consider a more efficient converter like a PTC.
You could also run out of injector with that turbo.
80s or 96s could be a better match.
