Just got my 87 Turbo T almost a month ago, now I have almost $300 saved up.
My car has a set of VDO gauges...oil, water temp and boost.
It also has an adjustable waste gate actuator rod, high volume oil pump, blue top injectors, unsure of the turbo but thought to be a TE-44.
Also have some sort of after market cold air intake with a K&N filter. The cat was swapped for a straight pipe by the previous owner and some Flowmasters were installed.
I'm wondering if I should first go buy a scan master? Or a hot wire kit? Or should I go get the after market reinforcement bracing for my car?
FWIW my car pushes 15 lbs boost tops.
Thanks.
Thanks.
