what size pump for 120s & 160 lb injectors
49-blues
What kind of flow numbers would i need to supply enough fuel for 120 lb injectors and also 160 lb injectors. i will be starting my stage2 motor with 120s and may go to 160s later and want enough pump to handle both either in GPH or LPH.
120#'s: weldon 2015 (good up to 80% dc), aero a1000 (good up to ~90% dc), in-tank double-pumper (good up to ~96% dc), sx 18207 or fuellab 41402 (up to 100% dc)
160#'s: sx 18207 (up to 80% dc), fuelab 41402 (up to 85% dc), weldon 2032 (up to 90% dc), aero eliminator (up to ~95% dc), fuellab 42401 (up to 100%dc)
thanks- thats what i was trying to figure out. going with 100% E-85 i should adjust for about 30% less because it takes that much more fuel flow with E-85?
A Robb McPerformance sender with 1/2" supply & return lines. still setting it up for 100% E-85.
Any hp estimates with those hardware configurations would be 30% less with E85. Or stated another way, you will need 30% more E85 flow vs that needed for the same hp level for gas.
