looking to pick up a set of four (4) brand new bfg ta radials from a buddy they are 255/65/15
will they work both in the front and rear with stock rims without any rubbing or hitting? would they be too wide for the front when making turns?
thanks
Wide will not be the problem, people run 255's all the time. You will have more of a problem with wide AND Tall. Stock size is 215/65R15, so a 255/65 will be Much taller. I think you will have problems with the combination (wider and taller) Plus a 7" rim is small for a 255. Best would ba a 255/50 and an 8" rim.
