what size tires?
dand
looking to pick up a set of four (4) brand new bfg ta radials from a buddy they are 255/65/15
will they work both in the front and rear with stock rims without any rubbing or hitting? would they be too wide for the front when making turns?
thanks
:confused:
Wide will not be the problem, people run 255's all the time. You will have more of a problem with wide AND Tall. Stock size is 215/65R15, so a 255/65 will be Much taller. I think you will have problems with the combination (wider and taller) Plus a 7" rim is small for a 255. Best would ba a 255/50 and an 8" rim.;)
