What times should i get.
If you want mid 12s I say fuel pump/hotwire,adjustable wastegate,adjustable fuel regulator,eliminate converter,kn filter/cold air,scan tool and some tires for traction.Your at the best stage of modifying your car from stock to mid to low 12 enjoy it.Save your money on all the high dollar parts you dont need them to get these cars to run low 12.Good Luck.
i didnt read your post right if you are not going to go over 20 psi your looking at a gain of 30 hp. i would say high 12's or low 13's
doesn't say anything about tires either.. reg street tires Ill still say 13s :cool:
Im with these guys..
Im a novice racer..my first time at the track the best I could get was
13.1@106 with a 2.1 60' on stock sized street tires.
This was on 100 octane at 20lbs boost..
with drag radials i got down to 12.8, same boost
havent been to track since getting alky
