What To Get Frist Alky Or Nos
aze12677
What To Get Frist Alky To Run Highter Boost Or Nos To Spool Faster I Got A 60 Turbo Need Some Help
The cool thing about a turbo buick, is you DON'T need NOS to make it go fast! Alky should be on any turbo car.
To run higher boost....give the wastegate a twist. Add Alchy and you go fast.
Don't worry about using nitrous. :cool: Unless of course, you pull up to the lights against someone who is. :eek:
Get both! An oversized turbo will Spool like a stock turbo with a 6" DP, and mix with alcy for your octane needs..high boost and 50+ from a relatively easy and affordable bottle install. That's what I'm asking for this Christmas.
6 inch DP? I didnt know one existed.... I thought RJC's 5 in was the largest.:confused:
I was exagerating, I mean with some NOS, the spool time on a fatter turbo would be like a little stocker with no back pressure...zinggggg:D
