quickturbo
- Jan 15, 2012
I'm wondering what valve springs I should use with a 87 GN motor with a 218-212 roller cam with 1.65 roller rockers and GN1 aluminum heads. The receipts I have from the motor build say I have K-750 springs installed. My motor gets to the 5200-5300rpm area and falls on its face. I eliminated all the electronics as a issue and in 90% sure my intake valves are floating at that rpm. My boost gauge will bounce around quickly in the 12-15 psi range at 5200rpm+ area. If I go to 18psi it will just fall on its face.
