What will spool be like with this Turbo/Convertor
  • Thread starter Thread starter AsphaltAnihil8r
  • Start date Start date
A
AsphaltAnihil8r
Guest
Ok the Convertor is a Pats 10/11 LU with 3400 stall.
the Turbo is described here:::Precision turbo with less than 400 miles on it. It is a PT 70 with the new 4" inlet and 3" outlet GT compressor housing. It has the Precision .63 turbine housing with the P-Trim exhaust wheel. It's a 3 bolt
Will I have a problems ...:)
you will have problems if your fuel isn't right....should be ok otherwise
agreed... I too have a Pats 3400 LU with a 63.. Does a nice job but need more GAAAASSSSSSSSSSSSSSS
actually, you need less gas.......as lean as you can get it on spoolup=hotter exhaust gas=quicker spoolup
I just put my 70 stealth in a car with a 2,800 Del-trans converter and it seemed to spool fine I was able to footbrake it to about 8psi.
