- Apr 4, 2002
Check the fuel line hoses just in front of the gas tank. Could be a bad, or kinked one.
Mike B.
Mike B.
SignUp Now!Sounds like your gauage isn't working right. Cause if you see 70psi on your guage your car would be flooded with fuel and shut off. Start with a new FP guage. Check the filter in your alky line. Also have a look at your nozzles inside your intercooler pipe for any blockage. Then move onto your fuel pump and filter if the issue has not been solved yet.
I was just thinking the same thing. I just checked my plugs and they look good actually. Now if Ive made a few short trips and the guage has been reading 60-65 lbs (line on) I would think they would have been fouled out. If alchy has been spraying would that be the reason they are looking ok?
Filter in alchy line? Wheres is that located exactly?
Negitive. That would have nothing to do with your plug reading unless you took a full pass and shut the car off immediately after and checked the plugs. If your plugs saw 65lb FP at idle they would be blacker then black and your car would chug like a horse and have a black cloud coming out of your exhaust. Your filter for your alky line is on your feed line going to the nozzles. Its really close to the pump/battery. I just ran in the garage to snap a pic of mine to show ya.
Looks like it was a bad guage folks.At least its nothing major.
Thanks for all the input and help fellas! I really appreciate it!![]()
