SignUp Now!So will a stock stroke iron head car spool the 6768 with the correct combo?
Stall would have to be around what a 3400?
6765 should go high to mid 9's?
6768 bottom 9's.
Just trying to learn...
That is pretty much correct on an all-out application. Most guys won't have all the pieces to push them that hard
I hope a stock stroke will spool a 6768hpq. That is my combo for next year with the .85 housing. The same engine (that was in my old tsm car) will be in my new car. That engine had no issues spooling a 70hpq and gtq. Not sure what the stall was though in That car. I just know it took a couple times to get it on the money. Problem is I switched from a th400 to a 200 so I will be in search of the right converter again. I got an old school art carr that will be tried first.
Eventually it will be pushed hard. I'm hoping to get where I left off with a 70gtq, which was 9.6's@142. There was a little left in that trim....I'm pretty sure I should get close at least because the 67 looks like it is rated higher or the same.
Kevin, are you going with an E cover to run THS?
Bryan
I believe you will be one of the contenders for this series. If my car ever decides to cooperate with me and stay together I may make the switch myself.
Bryan
Only issue right now is the money part or lack there of lol.
Aint that the truth. My wife just lost her job last Tuesday, car is on the back-burner now.
Good luck
Bryan
So, Cal what which would you recommend for the combination in my sig? I'm already planning on a different converter and more fuel.
It depends on your goals. If you are going to run the turbo to it's limit, your combination can support the HPQ. I wouldn't spend the extra money if it's mostly a street car. That extra 35hp comes at a cost of an additional $350 over the 6765. That cost is usually what seperates the racers from the street cars.
The THS Record holder has 6765 from Hartline. Stock stroke, iron heads.
Is the billet 6765BB a turbo that you keep in stock? (bought with your in-stock Christmas special price? )
